I am trying to remove the rear hatch off my 89 CRX Si. I got all the bolts off and that darn blk tubing with wires in it is my only problem. Where can i disconnect it from?
I just stripped out my 91 hatch and took off the stock spoiler (I'm junking the car).
the wires for the brake light were the way you described. black tubingfor wires
since i didn't care if I broke it I just tugged on the black tube, it had a lip that expanded inside the spoiler, just came right out of the hole exposing the electrical connector ,it was tucked inside the spoiler. I'm not sure if the wires you are dealing with are set up the same way. so be careful a rex is terrible thing to damage good luck hope this helps!
no there is a conector behind the right interior panel.it is in the bracing of the right quarter.it sucks.dont be a hack and cut the wires tho....do it the rite way.
