Rear light issue
Faramire
Hello All,
I have a 93 del sol, and for some reason my rear lights don't work when the lights are on, but the brake lights do.
Any common reasons why this would happen? How would I go about trying to solve this issue?
Thanks in advance!
Check for a blown fuse in the fuse pannel under the dash. More than likely your issue.
I have actually taken each out, and not only checked to see if they are bad, but I replaced each and every one of them, once it still didn't work, I checked my manual to see if the correct amps were in each.. 2 were off, but still, nothing fixed my rear lights :/
Would anyone know which fuse that would actually be?? Maybe i'll toss a bigger amped fuse in there....?
Here's a link to the fuse diagrams that should help you. Just scroll down a little bit.
