Rear Lower Tie Bar Question
BrutalB83
Brutal Moderator
Moderator
VIP
For anybody that has a rear lower tie bar on their ABS-equipped EG/DC, what did you do with the ABS mounting line brackets when you installed the bar? Right now mine are just zip-tied to the tie bar. I was wondering if anybody else had a better solution?
Yeah it's a rear lower tie bar. And I'm not talking about the actual brake fluid lines, I'm talking about the ABS wires, they're bolted to the subframe and the control arms with little metal brackets, and if you put the tie bar on then it's impossible to remount the brackets that go on the subframe, so I just had it zip-tied to the tie bar.
I figured out how to get rid of the brackets though, so I'm all good, it looks a lot cleaner. Thanks for the response though.
