Where should I go to get rear trailing arm bushings installed and buy the actual bushings themsevlfs? And is there any other aftermarket bushing sets for this besides oem ones?
You can order them online from any of hte hundreds of retailers, or if you have a performance shop in your area, go there. Any shop that does that kind of work (general mechanics) can do it.
One mechanic told me that installing the rear trailing arm bushings is rated at a six hour job in the book. In the meantime, I put 3M Window Weld sealant all around my old oem rta bushings and my teggy feels a whole lot better.
Stay away from poly bushings... they seem fine for motor mounts though.
How long have you had them on? Talking to Calesta, he said that poly bushings only last about 3-4 years... and the RTA's are such a PITA to change. I would have glady gone with the Mugen's except for the high prices. Also early in the summer, one of the poly bushings in my Si's rear LCA slipped out of place... between that and the creaking of the poly bushings, I am less thrilled with them all of the time.
Originally posted by 94RedSiGal@Aug 25 2004, 10:43 AM How long have you had them on? Talking to Calesta, he said that poly bushings only last about 3-4 years... and the RTA's are such a PITA to change.
Originally posted by 94RedSiGal@Aug 25 2004, 03:15 PM One mechanic told me that installing the rear trailing arm bushings is rated at a six hour job in the book.
