Rear Wheel Burnout
Discussion in 'Racing and Driving Techniques' started by sirkurtius, Mar 16, 2003.
  1. sirkurtius
    sirkurtius Member
    toronto canada
    what are the best techniques that u guys use for this?
  2. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    I would say buy a rwd car then go somewhere else
  3. 98integrals
    98integrals Senior Member
    Kzoo
    haha, thow ur FWD car into reverse, then hit the gas :D
    the front would then become the rear, and you would be doing a rwd burnout :spin:
  4. E_SolSi
    shit it would be rear engine rear wheel drive
    you just made a porsche 911 y0! :lol: :lol: :lol:
  5. sirkurtius
    sirkurtius Member
    toronto canada
    i guess no one has drive'n a S2000 or maybe a NSX?
  6. asmallsol
    we are kinda short the 25 grand for a used S2k and about 50-70k short for the nsx. yes honda do make rwd cars but it is not the norm.
  7. Distorted
    Distorted Member
    Seattle, Wa
    [Tips from a Valet] To burn out:
    Rev to point where your can spin the tires furiously
    Drop cluth or slip depending on axles
    Hold brake down while applying gas(if neccesary, usually not)
    Inhale!
    Brakes are usually proportioned to be front dominant, so rear brakes will often disengage under extreme loads, not always though.
    S2000 burn out very weird, their fun for AutoX traction system will usually put a stop to most burnouts, but a determined/skilled driver can get by this and they do burn out very well. hehe
    Rob :D
  8. Tonyd0821
    Tonyd0821 Banned
    umm whats the point in doing a burnout? unless you are at the track?
  9. E_SolSi
    honestly if you dont know how to light up the tires
    just go to your local DMV office and hand in your license
    ive lit the tires up on a rented 3cyl metro
    if you cant do it or dont know how to go about getting it to happed you shouldnt be behind the wheel of a car in the first place
    :bash:
  10. paragus
    paragus Senior Member
    :werd:
  11. sirkurtius
    sirkurtius Member
    toronto canada
    i didn't say i didnt know, but what do see is that u did not answer the question
  12. Canuck 93 Civic Si
    Canuck 93 Civic Si Senior Member
    Mississauga, Ontario, Canada
    Burnouts are fun as long as the tires arnt yours :p
    note: tread remains on outside edge cuz of lowering without camber kit :(
  13. KrUsHa
    KrUsHa Senior Member
    davie florida
    lol ive done that once :D :D
  14. E_SolSi
    and this is a race/driving technique?????
    :bash:
    :ufucktard:
  15. 98integrals
    Kzoo
    ok i figured out how to do this.
    take your normal average FWD honda, jack up the back end so BOTH tires are a good 3-4" off the ground.
    now grab 2 small buckets/pans... whatever it doesnt really matter as long as they are tall unuf to hold some water but short eunf to fit under the rear wheels (i guess u could jack the car up higher if u want)
    now.. fill those about 1/2 way up with some water.
    *note- quality of water doesnt matter, so tap water will do.
    ok here is the tuff part. Lower the jacks so the rear wheels are stitting in the water. Now go find some dry ice. im assuming you will need lots, plus the more you have the better it will be.
    throw that dry ice into the water and watch that shit smoke, FUCK! you dont even need the car to be running!
    :D
  16. E_SolSi
  17. liquid00meth
    liquid00meth Senior Member
    Laconia, NH
    1. rev car to mid-high range rpms.
    2. dump clutch if you need to. Slip if your clutch can take it.
    3. mat gas pedal.
    4. hold down brake if your stationary.
    5. Let off brake and move around, if your man enough.
    6. take pictures
    7. roast em till they pop.
    8. take pictures.
    9. get laid.
    10. take pictures.
    :D
  18. caffeind
    caffeind Senior Member
    Florida
    dude, i bet you 20 bucks you cant make my car burn out
    stock automatic 95 eclipse GSX
  19. asmallsol
    is the GSX 4wd (or awd) or fwd? If it is front, just floor it, your bound to get a little wheel spin, if not, wait till winter, put summer tires on it, have fun.
  20. Slo86GT
    Slo86GT Super Moderator
    Memphis - Hellhole of the South
    The X in GS-X means AWD.
    Plus, I drive a Mustang GT daily. Here's me at the track doing my burnout ;)
    I prefer the three pedal method... Hold brake with your toes of your right foot, feather/hit gas with heel, and drop the clutch with the left foot. Instant standstill burnout.
