Rear wheel hub assembly replacement
kmoallem
Hello,
I’m in the process of preparing trailing arms for a rear disc brake conversion on my 89 CRX (the trailing arms came out of a 91 CRX with discs). The problem is that the rear wheel bearing on one of the arms is shot …. does anyone know if a 1990-2001 Integra rear hub (found one on ebay for $48, guy lives nearby) will do? Also, the Integra hub has an ABS sensor, will this make it incompatible somehow? Or, can I just use the ones out of my current setup (with drum brakes)?
Would appreciated any advice.
Thanks in advance^_^
[FONT=&quot]Well there’s more … the two screws that hold the rotor down were so badly stuck-in and rusted that I had to drill their tops off to remove rotor … I was originally planning to completely drill through them and to re-thread the hole … but, since the bearing is shot, I rather just replace the whole thing.
[/FONT]
i had to drill those 2 bolts on my gsr stuff and mine is fine for 2 yrs now
