rear wiper
civic-93
Member
I have a 93 cx hatch, and i recently came across a rear wiper elctric motor from an eg si, i see that on the rear hatch window there is a box where you obviously put the motor, but where do i run the wiring from the electric motor to?
If I had my manuals, I'd tell you or sure, but memory says, it runs to a group of wires that runs on the driverside to the back, same cluster as tails lights etc...and runs up the side and connects just inside the car through the same channel as the third brake light.
