rebuilding for boost
Discussion in 'Civic and CRX - EF' started by 8ballsin, Mar 23, 2008.
  1. 8ballsin
    8ballsin New Member
    Heidelberg,Germany
    first of all i have a D16A6 completely tore apart i am going to rebuild it and i want to boost it i have never done anything like this before so i nned some help what are the things i should change i am assuming cam, pistions, valves but i dont know what would be the better brands i am looking to spend about $1000 on parts i am doing all the work myself
  2. INJEN78
    INJEN78 HS LEGEND
    OHIO
    what are your power goals???
    your not going to get far with 1g...
    in any rebuild you need all new bearings,seals,gaskets,hardware(bolts,nuts,washers)
    then a hone,and its good idea to have the block checked for problems
  3. 8ballsin
    8ballsin New Member
    Heidelberg,Germany
    the block is fine it only had a blown head gasket that i done im in germany so its kinda hard to get shit done for cheap so im doing all the work myself in the auto shop here on the army post the block has been cleaned and the only thing is the head i have to choices i can rebuild my head or i can put on the vtec head i have one here the reason i havent swapped them yet was because ive heard that when you boost a vtec it fucks shit up but didnt know for sure
  4. BrutalB83
    Rochester Hills, MI
    You heard wrong. It's fine to boost on a VTEC engine. You just need to make sure it's tuned well, but that should be a necessity for any turbo build anyway...
  5. INJEN78
    INJEN78 HS LEGEND
    OHIO
    ok so power goals??
  6. 8ballsin
    8ballsin New Member
    Heidelberg,Germany
  7. monotech909
    monotech909 Got V-tec?
    Inland Empire
    Sleeve the block and then take it from there.
    Eagle rods are good for its price.
    Arias turbo pistons are definately a good choice.
    If you plan on building it for that much Hp you will need to spend top dollar and that way you can make good boost. $1,000 is nothing for trying to gain that much horse power. Thats just enough to get you some pistons and rods.
  8. LS_VTEC
    LS_VTEC you get the BRAKE
    NJ
    Good information Scott, but your method of checking the seats isnt exactly sufficient enough. When the engine is under load is when the seats take the beating. A cylinder leakage test would be the correct method. Although your method will work IF they are severely unseated. :thumbsup:
  9. INJEN78
    INJEN78 HS LEGEND
    OHIO
    honestly i dont think your goals are realistic with the budget...
    you will need a good tune,all the new parts def new rods,because stock is guaranteed up to 200hp
  10. sevenhillsbilly
    sevenhillsbilly New Member
    i am doing the same build and if you are going to keep your budget to 1000 u wont do it
    and the vtec head is a great idea because it adds like 20 to 30 hp automaticly but the biggest thing is the tune after you bolt on a turbo and dont run over 16-18psi or you will blow your motor
  11. LS_VTEC
    NJ
    sevenhillsbilly, keep in mind PSI means nothing. If your engine only makes 200whp on 20psi due to the tiny blow dryer under the hood than its fine. Now on the other hand if you have a massive 60-1 under the hood, 20psi would definately toast your stock engine. 10psi on that engine with that much larger turbo will make more power than the smaller snail on double the boost. Fuel Tuning is key.
