I was looking at some stuff online trying to find some parts to rebuild my YS1 trans and I was wondering if you guys thing this would be worth the money or if I should just go to honda.
Acura & Honda 5 speed Transmission overhaul repair kit save money!
$237.27
On the same site:
BK Bearing Overhaul Kits (FWD) include all major bearings, input shaft bearings, main shaft (pinion( bearings, differential bearings, shift fork inserts, gaskets, seals and small parts when available.
Kits ending in WS include brass Syncro rings sets
Integra1992-1993
1.8lt 5 speed YS1
ALTBK390AWS
With Synchro rings
ball differential bearngs
72mm OD ball rear input bearing
$420.30
$237.27
On the same site:
Integra1992-1993
1.8lt 5 speed YS1
ALTBK390AWS
With Synchro rings
$420.30
