SolidDreamz
I JUST FINISHED my swap today, Started it on saturday. Got the engine running, took it for a drive not even 2 blocks down the road I hear a sound and the rpms would increase while in gear but the car wouldnt accelerate. pulled over. Now when I start the car have have the clutch pushed in, when I release the luctch even in neutral there is a wierd noise, maybe grinding. So you think my clutch is shot? Also when I finished the swap the clutch pedal didnt have much pressure but it didnt grind into gear to leave so I thought I could make it to a friends house to have him help me bleed the clutch. Is it because I might not have enough pressure in the lines or do you think the clutch is shot? One other think not important is when the rpms go up in neutral the speed odometer rises with it? Thanks for any help.
