i was wondering if i could put my b18 into another integra, and if reconmended. or should i go with the honda. it is a 95 b18c1. what integra would work the best and is it possible for a 4 door?
Yes, your 95 C1 will fit in just about any other Integra 90-01 with little to no modifications. For pre 94 back to 92, you'll only need a cable tranny, for pre 92 you'll need some wiring to backdate the electronics, along with the cable tranny. 94+ it will be more or less a straight forward remove and place. Wiring in vtec to the ECU as needed for non vtec models.
