Red Line Oil Now Available at CorSport
Discussion in 'CorSport' started by CorSport, Sep 14, 2011.
  1. CorSport
    CorSport Member
    [​IMG][​IMG] [​IMG]
    Click here to see this product in our catalog and check out the most current pricing.
    ABOUT RED LINE MOTOR OIL
    • Fully-synthetic ester formula for passenger cars, light trucks, performance vehicles and marine applications
    • Excellent wear protection and friction reduction across a wide range of operating conditions
    • High detergency allows extended drain intervals and provides increased cleanliness
    • Improved fuel economy and ring seal for more power
    • Superior high temperature stability and oxidation resistance increases
    • lubrication of hot metal compared to other synthetics
    • High natural viscosity index (VI) provides thicker oil film in bearings and cams
    • Less evaporation than other synthetics for improved efficiency and ring seal
    • All products are completely compatible with other conventional and synthetic motor oils
    If you have any questions you can reply to this thread, send us a pm or use the contact us page on our website.
    Thanks for the continued support,
    CorSport USA.
  2. CorSport
    CorSport Member
  3. CorSport
    CorSport Member
    Red Line Oil Full Synthetic 0W20 Motor Oil (5 Quarts)
    [​IMG][​IMG][​IMG]
    Recommended for small cars and hybrids, and some trucks like Honda Insight and Civic Hybrids, Toyota Solara, Camry, Rav4 and Tundra 5.7L, Venza
    Lightest passenger car motor oil available from Red Line
    Increased fuel economy and improved wear at cold start
    Better flow at extremely cold temperatures compared to 5W20
    Recommended for API SM/SL/SJ/SH/SG/CF and ACEA A5/B5
    Superior high temperature stability and oxidation resistance increases lubrication of hot metal compared to other synthetics
    TYPICAL PROPERTIES
    API Service Class
    SM/SL/SG/CF
    Viscosity Grade
    SAE 0W20
    Vis @ 100°C, cSt
    8.2
    Vis @ 40°C, cSt
    43
    Viscosity Index
    166
    CCS Viscosity, Poise, @*C
    55@-35
    Pour Point, °C
    -60
    Pour Point, °F
    -76
    Flash Point, °C
    216
    Flash Point, °F
    421
