Redline Question
Discussion in 'General Tech and Maintenance' started by keehnel1414, Apr 18, 2003.
  1. keehnel1414
    keehnel1414 Senior Member
    i was wondering what the redline for d16y8 is and the redline for the b18b? I would like the stock redlines.
    Thanks for all the help.
  2. 2fastaccord
    2fastaccord Senior Member
    d16y8 is around 7000 and the B18b should be around 6750. Correct me if I am wrong this is from straight memory.
    Peace*
  3. keehnel1414
    Do you know where i can find this out?
  4. 2fastaccord
    find some people that have these actual cars, other than that I don't know what to tell you. I can assure you that the D16y6 SOHC Vtec is going to tach up higher than the B18B and I know that it will tach up to 7000 on the dash before reaching redline. I am not 100% certain on the B18B it is around 6500 to 6750 though.
    Peace*
  5. keehnel1414
    Well i just want to know what d16y8 redlined at so thank you for the help. I threw in the b18b to compare?
  6. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    I have a d16z6, which is the early edition of the y8. On my z6, the redline is 7200
  7. ayaran
    ayaran Junior Member
    I've got a D16y8 and the redlien is 7200 the same as the z6.
  8. Baker
    Baker Senior Member
    Schaumburg, IL
    i don't know what b18b you've seen but they redline at 7000
  9. wildbillhatchbac
    wildbillhatchbac the OG VIP
    werd. . . the rev limiter hits at 7500 on the b18b . . . i think, and hope ;)
  10. trulunacy2786
    trulunacy2786 New Member
    my rev limiter on my b18b hits at about 7100-7200ish
