Reliable ls/Vtec
Discussion in 'Integra' started by dafalllbackkid, Dec 4, 2008.
  1. dafalllbackkid
    dafalllbackkid New Member
    I am looking do Vtec my ls , but i have a few questions like.
    -how long will it take
    -What parts do i absolutely need , and which parrts can i substiute for less expensive ones.
    Please info from ppl who have done the swap , want ppl with experience .
    ** if you dont have anything constructive to say , then dont say anything at all ***
  2. austin20110
    austin20110 New Member
    Northern Va
  3. 95b16coupe
    95b16coupe New Member
    ct
    when building a motor, why would you want to go on the cheap? if you do something cheap, it will break. then you will have to spend money to repair it. in the long run, it will cost more than to have built it right the first time.
    not gonna happen, not on this forum.
  4. dafalllbackkid
  5. dafalllbackkid
    vtec
    Ok so then what do i need to move forward with my build and how much am i looking to Money wise?
  6. 95b16coupe
    ct
    if you don't know what you need to do the swap, odds are you have very little mechanical experience.
    I would personally suggest just doing a small turbo setup or if you want to stay n/a, just get some really good cams, i/h/e and a great tune. you would be faster than ls/vtec for about the same money.
  7. austin20110
    Northern Va
    maybe if you did 20 secondds of research you would not have been called a noob
  8. George777
    George777 ^^ Likes Bewbies
    With your mom
    Based on research I have done, you will need about $3k to put together a well-built LSV. That is assuming you already have the head and block and will just be purchasing internals and paying for machine work.
    If you shop around, you could probably find stuff cheaper, but it's a rough number. And if you are going to build it, get it tuned. If you can't spend the money to get your car tuned so it runs right, then don't bother building it--you will be wasting your time.
  9. BrutalB83
    Rochester Hills, MI
    Read the damn article that was linked to. It's a perfect walk-through with an extensive parts list. Cost will depend on what you're going to do with it (just straight up LS/VTEC or add additional upgrades)...
  10. brandanintegra
    brandanintegra New Member
    yes ls vtec is the shit ive been driving mine for 3 months now an no problums
  11. teggyguy
    teggyguy high density foot.
    Colorado
    hahahaha
    wow if you can't handle an occasional :stfunoob: then wouldn't recommend being on any forums.
