Removing a/c evap???
Discussion in 'General Tech and Maintenance' started by udcivic, Aug 18, 2008.
  1. udcivic
    udcivic SiR-G
    Janesville WI
    ok i swapped a b18c into my 99 civic....i got red of a/c for future turbo reasons, everything is out under the hood, my question is...is it ok to remove the a/c evap. from behind the glove box, an what are the pros and cons from doing this?
  2. BrokenRex
    BrokenRex New Member
    pros : less weight....
    cons : two holes in your firewall
  3. George777
    George777 ^^ Likes Bewbies
    With your mom
    Cons: Sweaty balls and swamp ass
  4. 91accordwithwork
    91accordwithwork kid that everyone loves!
    Wauwatosa WI
    and diarehia
  5. BrokenRex
    well he already has the rest of the system removed, so the only new cons would be the two holes in the firewall. he lives in a cold climate though, so freezing his ass off because the holes let in cold air is probably more relevant than the swamp ass.
  6. udcivic
    udcivic SiR-G
    Janesville WI
    so when i take it out, i just unplug the harness from it and leave the plugs hang their....
  7. V8eater/GSR
    V8eater/GSR New Member
    Salt Lake City, UT
    thats all i did in mine and use vinyl tape for the holes colors are fun ha ha battery hides everything if you remove the cooler more stuff can get into the interior like BUGS plus the weight diff wont make a diff but if one day you decide to put it back or someone else does you wont have crap inside it. you could cut the harness just make sure to take care of the ends so there arent any sparks
  8. udcivic
    udcivic SiR-G
    Janesville WI
    took it out but now i have no heat ..when i turn on the heat nothing happens
  9. budda
    budda New Member
    Cincinnati
    then i'd plug that effer back in.
  10. awptickes
    MD
    Please tell me that you had the system purged before you 'got red of a/c'.
  11. udcivic
    udcivic SiR-G
    Janesville WI
    sure did...i did it all the safe way...i took it to a buddy's shop and had it done.
  12. BrokenRex
    why? it's a 99, so it's got r134a, not r12. r134 is not harmful to the atmosphere, and is non-toxic unless exposed to an open flame (which unless you're smoking while purging it, or purging in a confined area like your garage, wont hurt anything.) if you have a gas powered hot water heater in your garage you could run into trouble, but the stigma with refrigerant stems from r12, not r134a.
  13. awptickes
    MD
    To begin with: it's illegal.
    To end with: Would you breathe r134a in? I'll even buy the tank.
  14. BrokenRex
    you win, purging to atmosphere is illegal. and no i wouldn't breathe it. but on the same token, it's not harmful to you or the atmosphere if you go about it safely (and yes, the responsible thing to do it have it evacuated correctly.)
  15. George777
    With your mom
    Having it evacuated safely and responsibly is the responsible thing to do, as well as the legal thing to do, and will give you even better chances of not getting injured.
  16. BrutalB83
    Rochester Hills, MI
    And....fail.
  17. jdmcivicgsr
    jdmcivicgsr jeremy
    springfield il
    i did the same in my 94 civic and i took the firewall rubber gaumets out of my d15 hatch and the fit right in the wholes where my ac and evap were looks normal and no tape is needed
