randerson165
Do I need a special tool to remove the o2 sensor ? i'm switching header and exhaust with a buddy and i want to know if I need a special tool or how do you take it out ?
Also, do I have to jack up the car a whole lot to get the header off ? you unbolt it and drop it out the bottom correct ? will the standard jack that comes with the car lift it high enuf ?
