Removing Tail Light Tint
Discussion in 'Other Vehicle Discussions' started by hunter4life, Feb 1, 2009.
  1. hunter4life
    hunter4life Rotary Man
    Canada
    Okay I need to remove the tint on my tail lights (bought it like that) and I was wondering what is the best way to do it? I've looked on the net and lots of people say use something like paint thinner or stripper but I'm afraid it will wreck the plastic. So is wet sanding the best way to go? and does anyone have any detailed instructions on how to do something like this. It doesn't look complicated but I don't want to wreck them:(. Thanks for any future help..
  2. 99sidude
    Ohio
    Try acetone. If i'm not mistaken it shouldn't hurt the plastic. At a fiberglass shop I interned at we used it all the time to take shit off our hands. If it won't hurt your skin I doubt it will hurt the plastic.
  3. OGMatt
    OGMatt Not a real OG lol
    vic B.C. Japanada
    get new lights sell old
  4. austin20110
    austin20110 New Member
    Northern Va
    laqueor thinner will work well after you peel off the old tint.. to remove the glue... with wet sanding you will need a buffer, and compounds to remove the scratches
  5. hondasaurus
    hondasaurus Member
    VA/DC
    those cars look so much better w/ a spoiler and the right rims.
    some say heat gun and peel/scrape it off w/ goo-gone or some adhesive remover. not sure if someone tinted those or if they were manufactured that way. i'd say try things that work for removing window tint if in doubt.
  6. hunter4life
    Canada
    Well I just went ahead and wet sanded them tonight. My friend came over to help and took us about 7 hours...that might have been to long, but it worked. The guy layed on three heavy layers of clear coat so it took awhile. I started with 1000 grit and just kept sanding..it worked but was taking to long so I moved down to 800 and it worked a little bit better. If there were any scratches I did use some 1500 for a couple minutes and that helped smooth it out. I've never really done any sanding or bodywork but my little project went well^_^. I just used some Meguier's PlasticX and ColourX after and it really took the fogginess out. As far as I can see I did a pretty goood job, they shine and arent scratched...only thing left to do is the mufflers now. (I got a speeding ticket so cop nailed me for tint and my mufflers, which aren't even loud...oh well). I'll post some pics if anyone is interested.
    Note: Hondasaurus I have spoiler and saving for some rims...stock doens't even look bad.
  7. hondasaurus
    hondasaurus Member
    VA/DC
    i meant your current setup looks good. i had a 2nd gen w/ stock cookie cutter wheels and no spoiler and it wasn't the best look.
  8. hunter4life
    Canada
    Oh okay...yah I know what you mean I had a chance to pick up another one, this time an 86 and they just don't look as good
  9. get_nick
    Washington State
    i would just try to get new lights. that stuff is hard to clean off.
