Can someone help me in removing the crank pulley? That bolt sure is stubborn, my impact gun isn't strong enough to take it off, and when I tro to do it manually it just turns the engine..what do I do?!?!?!?!
Put the car on the ground, e-brake on and in gear. Turn the wheel all the way to the left. Get a long-ass 1/2" extension, put a 19mm socket on it. Put that assembly on a breaker bar. Get a 1" diameter pipe that's around 36" long, stick it on the end of the breaker bar. Have a friend hold the socket on the crank pulley, then start cranking on the ghetto-rigged "impact gun">
