repinning my ecu
Discussion in 'ECU's, Electronics, and Tuning' started by supaCOUPE, Sep 17, 2004.
  1. supaCOUPE
    supaCOUPE Member
    just recently did a 99 SI swap, into my 96 dx coupe. I am using the dx engine harness and an obd2a to obd1 conversion harness. i have to repin my dx harness, but how do i pull the pins out with out doing damage to them? is there a trick to it?
  2. pissedoffsol
    umm, what are you re-pinning? for vtec wires?
  3. supaCOUPE
    supaCOUPE Member
    yep!
  4. cvc2f2f
    cvc2f2f Junior Member
    depends on the size of the connector, if it is a 2 row connector, then u can use a really small flat head into the other direction that will release the connector...... if 3 rows,,, then maybe a sharpened point of a paperclip............
