Replace Head Lights
Discussion in 'Body / Exterior / Interior / Cosmetics' started by kashnburn, Sep 22, 2005.
  1. kashnburn
    kashnburn Junior Member
    Having problems with my 95 Civic DX stock headlights. Discovered that all my connectors had melted. So time to replace the headlights and harness. What would be a quick fix to this problem. Nothing to fancy though but nice with good visibility.
    Thanks,
    Kash
  2. VTECin5th
    VTECin5th Administrator
    Phoenix Az
  3. kashnburn
    Thanks VETCin5th.
    Checked out your link, Very Nice!
    Another question, if my exisitng headlight harness is melted and useless how would I wire these up.
    Thanks,
    Kash
  4. Battle Pope
    Battle Pope New Member
    Southern Oregon Coast
    your chassis-side harness is melted? Buy new connectors, cut the wires back, install new connectors. Then your harness might be too short though.
  5. E_SolSi
    go to the junkyard and get some new plugs... just make sure you cut them with plenty of wire so you can make sure they reach
  6. VTECin5th
    Phoenix Az
    Yep, it's goin to be cut and paste from here, but it will be worth it when you can so freakin good.
