Take the bulb out of your projector and look at it- the bulb size should be stamped or printed on the bulb base. Sometimes (definitely on DOT "approved" housings) the bulb size will be stamped on the housing's lens.
That's actually what I ended up doing... it was easier for me to take the front end of the car apart than pull bulbs out the back of the housings. Big hands suck.
just bought a 93 civic dx w/ d16 sohc and it had 1pc projectors in it. All the bulbs where burned out except one. All of the bulbs were h1 bulbs and i bought the replacements at wal-mart and the way you take out the ones i have is there is a little silver clip you have to undo in order to take them out and also you have to pull the positive wire off of the bulb
