replacing '96 civic rt side axle
Discussion in 'Civic and del Sol - EG and EK' started by justillthen, Jun 30, 2008.
  1. justillthen
    justillthen New Member
    I am replacing the passenger side axle on my civic and all went well till I went to remove the disconnected axle. It did not come out thru the gap in the lower end of the strut. CV's on both sides were too big. The next step would have to be removing the strut so to remove the axle. Is this the case or is there some other maneuver that I can do that would avoid strut removal?
    Thanks for the help.
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    naa you got to remove the lower bolt, the top of the strut dont haver to be taken out but just take the lower bolt out that holds it in place
  3. justillthen
    Thanks for the post on that. I did pull off the bolt earlier and made a happy union of the new axle. It just was not what I had expected to need to do when I went into it. Yet, it was no thing.
  4. thetunersource
    thetunersource New Member
