Reset ECU
dc96819
Does the ECU need to be reset after replacing a bad crank sensor or any part that throws a code?
Yes, disconnect your positive battery cable for a min or so then plug it back on. This will reset the ecu, and there should be no check engine light unless there is still a problem.
