A aphex301 Member Oct 5, 2003 #1 if you have to reset the ecu after putting on a test pipe and o2 sims to get maximum hp , how do you do it? is simply taking out a fuse or disconnecting the battery ground enough, or is it deeper than that? ....for off-road use only.
civicious Buck Futter VIP Oct 5, 2003 #2 disconnect the negative battery cable and count to 8 million. ten will do...but with 8 million, you can be even more sure that it's reset.
A aphex301 Member Oct 5, 2003 #3 ok ok ok thanks! im gonna start counting, once i take off the negative ground. thanks for the help! :fuckyou: smartass.
