Does the following SRS reset technique work for a 2002 Accord V6 ? If yes can someone tell where exactly to look for the plug or better yet if someone has a picture illustration the two wire yellow plug that will be great .. Thank You
1st step in erasing the memory is to turn the ignition off and connect the SCS Service connector to the MES Plug,
2nd Turn Ignition on. SRS indicator light will come on for about 6 seconds then go off.
3rd Disconnect SCS service connector for MES connector within 4 seconds after SRS indicator light goes off.
SRS indicator light will come on again.
4th Reconnect SCS service connector the MES connector within 4 seconds after SRS light comes on. SRS indicator
light will go off.
5th Disconnect SCS service connector from MES connector within 4 seconds. SRS indicator light will indicate that
memory is erased by blinking 2 times.
6th Turn ignition off, and wait 10 seconds. Start vehicle like normal and light should come on and go out like normal.
You have reset your SRS light, congrats.
light will go off.
