resistor box
1gEF-8
are there any differences in resistance between integra and crx resistor boxes?
[post=482909]Quoted post[/post]​
I asked this too and all I got was that a resistor box is a resistor box, they both do the same thing.
Originally posted by b16efhatch@Apr 4 2005, 11:11 PM
Not if you have the LS box.
[post=482920]Quoted post[/post]​
so it would be best to use the ls box with ls injector rather than crx box with ls injectors
Originally posted by 1gEF-8+Apr 4 2005, 10:15 PM-->
b16efhatch
[post=482923]Quoted post[/post]​
Not too sure on that one. I think they will be the same, not 100% positive though. I am going to be using an LS resistor box on my b16.
The crx vtec (b16a1) injectors are 2.45ish ohms. The b16b injectors that I just put in are 11.5 ish ohms. I didn't check what the resistance of the box was before I removed it but that may give you a starting point - check the ressistance of both sets of injectors and if they match, taaa daaa!
:D
:D
[post=483570]Quoted post[/post]​
They are the same.
