resistor?
ef_hatch
Member
what resistance does the knock sensor have? i need to bypass my knock sensor and don't want to chip the ecu
-Matt
-Matt
[post=382324]Quoted post[/post]​
What you're thinking of is not possible.
-Matt
Why not? it is a simple and painless procedure, and your car will be better tuned for it!
I could be wrong on this reason why simple resistor would probably not work. A *knock* sensor probably is some type of a pulse sensor, creates a pulse for every knock, a resistor doesn't make any pusles.
It is some sort of microphone that the computer uses to listen for certail telltale harmonics of a detonating motor.
