Resleeve/Bore ?
Discussion in 'Engine Building' started by one3two2three1, Jan 25, 2003.
  1. one3two2three1
    one3two2three1 Junior Member
    WHEN I WANT TO GET MY BLOCK SLEEVED
    WOULD THEY HAVE TO BORE IT OUT TO FIT THE SLEEVES
    IF THEY DO HOW MUCH WOULD IT COST
  2. phunky.buddha
    Dallas / Fort Worth, TX
    1. Turn off the caps lock
    2. Start your own thread, don't pollute someone else's- I split your post off for you this time
    To answer your question- there is no answer. If you want to resleeve, you don't have to bore out the block. If you want to resleeve your engine for larger displacement by using larger than normal bore sleeves, then yes you'll have to bore out the block to fit it. Most of the time, you'll be resleeving the engine with stronger sleeves that are strutted for even more strength, and then boring out those sleeves to the size you want. You're not boring the actual casting of the block in this case.
