Ressurecting my CF hood
Discussion in 'Body / Exterior / Interior / Cosmetics' started by CorysHBB2, Nov 15, 2010.
  1. CorysHBB2
    CorysHBB2 Member
    Norfolk, NE
    This is my first write up so bear with me ;)
    The clearcoat has been peeling and yellowing for awhile so i figured it was time to do something about it
    I started sanding with 320 grit on a palm sander to completely strip the clear off
    I then used a cheap white spray can primer for a guide coat to make sure i got all the 320 scratches out when i sanded with 400 and again with 600
    I then wet sanded with 1000 grit as a final sand before clear.
    I did my buddys Evo 8 spoiler at the same time
    I wiped it down with wax and grease remover and tack clothed it
    I used Keystone Euroclear
    I had to bust out the tweezers a couple times cuz the damn bugs kept landing in it in between coats. 5 coats later and :D
    My buddys spoiler
    Before sanding and buffing
    And after
    sorry about the quality of the pics all i have is my iphone :shrug2:
    DIY link: http://www.clubcivic.com/board/showthread.php?t=63197
    1 person likes this.
  2. E_SolSi
    good write up :thumbsup:
  3. hondafreak513
    hondafreak513 New Member
    O hi O
    That looks good I didn't know it was that easy to re-clear coat them.
  4. BBYEVO
    BBYEVO New Member
    Very easy.. just time consuming haha. Thats my Evo there. The bottom portion of the wing was peeling to the point were the carbon was showing..:eek:. Anyways BOTH look a lot better then before... BTW Good Write Up!! :rimshot:
  5. TurboMirage
  6. hueso0
    hueso0 New Member
    wow good info and work
  7. iplayintraffic
    iplayintraffic New Member
    Wanna do mine? lol...mine looks like shit. I really wish someone i knew could do it lol...Id make them help me lol.
  8. CorysHBB2
    CorysHBB2 Member
    Norfolk, NE
    you can do it its really not that hard :cool: the clear is the only tricky part :confused: and if you screw that up you can always sand it down and try again.or theres always the option to take it to a shop after you sand it and have them clear it. it might run you $100 or so. either way the finished product is gona be :D:D:D
  9. iplayintraffic
    Hahah true. I may just try to trade it for a stock hood.
  10. IDMaxGuy
    IDMaxGuy Senior Member
    MO
    wow thats excellent!
  11. dilbeckskate
    dilbeckskate infamous
    Kennesaw Ga
    That looks great bro, turned out awsome
  12. madjdmyooo
    madjdmyooo New Member
    how do i fix mah cf hood its fadinn da shine off
  13. hondafreak513
    O hi O
    Read the tread it says how to fix it.. there also is another thread on fixing a cf hood..
  14. CorysHBB2
    CorysHBB2 Member
    Norfolk, NE
    ^ what he said. theres a link at the bottom of the write up for a similar one.
    its basically sand and spray
