Rev limiter queston
Discussion in 'Integra' started by mountainracer1988, Jan 14, 2009.
  1. mountainracer1988
    mountainracer1988 LS_TUNER
    pa
    Anyone know if there is a way to disable the rev limiter in my 92 teg without a chip or EMS the computer is a PR4
  2. serrilion
    serrilion In my own little world! VIP
    Vermont
    I would look into postibly the ecu. I kno on some civics and Eclipses I have done, if you cut out the Gov Limiter in the ecu. It is a Resister on the brain. Just something to look in to! Btw I dont think ya have a rev limiter, U mite have a fuel cut off, not postive tho
  3. 93civicracer
    93civicracer Oh, I do a little here and there.
    Texas
    I wouldn't touch it unless I had a very tough valvetrain :).
  4. serrilion
    Vermont
    LOL, maybe he is looking to make fireworks out of it :):rolleyes:
  5. BrutalB83
    Rochester Hills, MI
    Is your engine relatively stock? If so, then removing the rev limiter would be fucking stupid. The rev limiter is there for a reason. First off, your car isn't going to continue to make power the higher you rev it. The power production will drop off at a certain point so it's pointless to rev that high unless you've built the engine to perform differently. Second, unless you've upgraded the valve train then you're likely to damage your engine by over-revving it, so once again, there's absolutely no point to this...
  6. austin20110
    austin20110 New Member
    Northern Va
    but but but his friend revs to 15k on his bike and he has to 1 up him...
    but like brutal said if you dont have anything done to it the rev limitor is there because your not going to make anymore power after it... actually your not going to make power before it even kicks in
  7. teggyguy
    teggyguy high density foot.
    Colorado
    Just tell the ecu you don't need a rev limiter
  8. austin20110
    Northern Va
    make sure you say please.... stuck up bastards
  9. teggyguy
    Colorado
  10. mountainracer1988
    pa
    JE high compression pistons eagle rods performance rod and main bearings skunk 2 cams titanium valve springs and too much other shit to name so ow if everyone is done pissing around and telling me what not to do ill take some actual advice now it s still pulling hard as hell at 7200 rpm's i know it will make more power after that
  11. phyregod
    phyregod !!YTINASNI
    Central Texas
    Titanium valve springs, eh?
    :fucktard:
  12. !JDM_EF-9!
    !JDM_EF-9! I'm just EF'n..
    cailfornia
    still dissing your shitt!! hahaa:owned:
  13. BrutalB83
    Rochester Hills, MI
    And you're running this on a stock PR4?
  14. austin20110
    Northern Va
    if you have all that done how do you not know anything abou ecu's jackass
    bought not built huh
  15. !JDM_EF-9!
    cailfornia
    or ran outta money before he got to the ecu part haha..
  16. je power
    je power New Member
    my house
    not that i no of u got to chip the ecu
