rev limiter
elpayaso201
okay is there any way to remove the rev limiter by cut or grounding a wire coming out of the wiring harness i have b18 and it only hits 6500 rpms HElP
The Rev-Limiter is programmed in the ECU. The engine is controlled by interrupting spark to the engine. You could cut the white wire comming from the dizzy and wire it to the battery's positive but you would fry your ignition coil.
why do you want to remove your rev limiter? do you have a fully built head? do you have an upgraded block? does your engine make power past 6500rpm?
no, no, and no.
leave it stock.
