rev limiter
Discussion in 'Accord' started by accordex98, Dec 2, 2008.
  1. accordex98
    accordex98 New Member
    how can i get reid of my rev limiter
  2. efhondakid
    Akron-Canton, Ohio
    You need it, it is there because after the set rpms your motor stops making power, and can do serious damage to your motor.
  3. BrutalB83
    Rochester Hills, MI
    :werd:
    Why do you want to get rid of your rev limiter? If your engine isn't built to rev higher then the factory red-line, you can damage it. Also, are you using after-market cams that will allow you to make power in the range you want to rev to? If not, then there's absolutely no point in doing this...
