rev problems, what could it be?
Discussion in 'General Tech and Maintenance' started by supaCOUPE, Sep 17, 2004.
  1. supaCOUPE
    supaCOUPE Member
    i just recently swapped a 99 SI motor into my 96 LSI coupe (euro spec dx, with ex luxuries). the swap was succesful, but i am having problems.
    when i try to keep the car under 1-3k rpms, the rpms sputter (go up and down, over and over) it almost sounds like i'm doing it on purpose. i have to give it alot of gas just to get it going. and it happens in every gear when i go below 1-3k rpms?
    i was told maybe my TPS was bad, but i am not sure? just hope it's not expensive!
  2. reckedracing
    reckedracing TTIWWOP VIP
    NY
    are you throwing codes?
    what ecu are you running?
    what wire harness?
    and what does the euro spec dx consist of?
  3. 97CTR
    97CTR Senior Member
    is your ignition timing set correctly?
    check for vacuum leaks
