Reverse Lights isn't working
Discussion in 'General Tech and Maintenance' started by turbo99, May 5, 2006.
  1. turbo99
    turbo99 Member
    Northern Cali
    I noticed that my reverse lights don't light up when backing up. It was working before. All my other lights light up except for that. I did an auto/manual swap a few years ago. The fuse is fine and the light bulbs are too. Any ideas on what to check for?
  2. wanderinman
    wanderinman Senior Member
    Raleigh, NC
    There is a sensor that lets the car know you've selected reverse, and without it (or with is being bad) your reverse lights wont come on.
    What car is it, and what was the swap?
  3. turbo99
    turbo99 Member
    Northern Cali
    It's a 99 civic dx with an LS tranny and LS motor swap. It used to be an automatic.
  4. -94-AccordH22
    -94-AccordH22 Senior Member
    assuming its the same as my accord. you have to hard run the 2 wires from the revers switch ON the tranny to the pinouts in the console where you old shift selector was.
