reverse noises..
Discussion in 'General Tech and Maintenance' started by eg6sir, May 23, 2006.
  1. eg6sir
    ok.. when i go in reverse its make this crazy noise. Kinda a whining noise and no its not the normal reverse whine, its loud.. i am kinda hard of hearing but my GF said she heard something while i'm driving... is it my brakes because thats the only thing i could think of..
  2. wanderinman
    wanderinman Senior Member
    Raleigh, NC
    Brakes really shouldn't make a whining sound, especially not one that sounds like a tranny whine. Maybe it is a normal reverse whine and your fluid is getting low/worn out. Try replacing your transmission fluid and see if that helps.
  3. eg6sir
    i replaced the tranny fluid a couple of months ago.. it doesnt sound like the normal reverse whine... it sounds like metal vibrating kinda
  4. wanderinman
    Raleigh, NC
    Something loose? Have you checked all the nuts/bolts/fasteners? Can you tell a more specific area the noise is coming from other than the front end? Have someone walk outside of the car while you drive in reverse and see if you can't pin down the location better.
  5. eg6sir
    alright... my buddy is coming by in an hour or so... i'll know more later tonight..
  6. wanderinman
    Raleigh, NC
  7. eg6sir
    got drunk and forgot about it... i'll know more tomorrow ..
  8. infamouz
    infamouz Senior Member
    Sacramento, C.A.
    could be your front or rear wheel cluster where the wheels fit in. i had that on my crx and we took off the wheels to find that the cluster was shot. I went to a special honda and acura junkyard here in cali and got two of them form 150 total. about 1 hours work for a mechanic i think. 2 cents...
  9. eg6sir
    wheel cluster??? what and where is that??
  10. phyregod
    phyregod !!YTINASNI
    Central Texas
    Must be right next to the flux capacitor...
    Maybe he means bearings? Or perhaps the whole spindle/brake/rotor assembly??
    P.S. My CRX usually squeeked from the rear brakes in reverse.. Its just something they do. You can fix it with new pads and/or that "squeek stop" grease crap. It didnt bother me that much though.
    P.S.S. I just love these after thoughts.. You didnt put transmission fluid in your transmission did you?? They use motor oil or "honda" transmission fluid (motor oil re-labled) in the Manual transmissions.
  11. eg6sir
    i used GM synchromesh in my tranny.. i'm gonna replace my brakes and see if it goes away
  12. eg6sir
    well.. i havent changed my brakes yet, but me and a friend came to the conclusion that its the brakes... i parked on a slanted driveway, turned off the car and let it roll back in neutral so we could listen and he said it was definitly the brakes..
    i think its time to upgrade while i'm in there..
  13. wanderinman
    Raleigh, NC
    Might as well, when I had a brake problem w/ the integra I put in brembo blanks and Hawk HPS pads, loved that setup and it was like, $150 for all 4 corners.
