Reving It self
Discussion in 'General Tech and Maintenance' started by joedain, Feb 17, 2005.
  1. joedain
    joedain Junior Member
    Idels at 3 grand, i pull out gas pedal then it drops to 1 grand then it revs its self up to 2 grand then back to 1 grand and repeats it self...Why does it do this?
  2. B16CRX
    B16CRX Senior Member
    Greenville, SC
    most likely your IACV. or bad vaccum lines/conections. DO you have a CEL?
  3. Slammed90Lude
    Slammed90Lude Senior Member
    milford, PA
    vacuum leak more than likely, a blown intake manifold gasket will also cause this
  4. civicdx92
    civicdx92 Senior Member
    MN
    i had a guy that worked on my talon a while back and broke my intake manifold assembly. so to cover it up he literally tried to glue it back together. when he gave me my car back it had that same problem. my problem was more severe however b/c it seemed like everytime i turned the car off and turned it back on the rpms went up higher.
  5. reckedracing
    reckedracing TTIWWOP VIP
    NY
    hmmm, low on coolant? tps? sounds like your throttle cable is too tight?
  6. B16CRX
    Greenville, SC
    too tight throttle cable would cause the revs to stay at a constant high.
  7. 92civicb18b1
    92civicb18b1 The Trisexual
    does it rev any higher than 3k?
    Either way I vote Vacuum line or IACV. Possible FITV but that's a lot more rare/
  8. 92civicb18b1
