Revs
Discussion in 'General Tech and Maintenance' started by vtecjdm, Aug 3, 2005.
  1. vtecjdm
    vtecjdm Senior Member
    Just did an obd2 to obd1 ecu swap and now the engine wont rev over 5000.
    Reconnected my obd2 ecu it runs ok, but i just need to switch to obd1.
    Could it be wiring problem?
    ANY comments much appreciated.
  2. jamesA
    I'm sure the first question will be; What engine and ECU are you running?
  3. integraslut78
    integraslut78 Stylus DJ Extraordinaire
    KiLLa kALi
    It sounds like a problem with the OBD2 to OBD1 conversion harness something in the wiring.
  4. B16CRX
    B16CRX Senior Member
    Greenville, SC
    is your obd1 ecu socketed and chipped? sounds liek a rev limit to me.
  5. vtecjdm
    Running d15b vtec on an obd2a and runs fine.
    Got a p28 with obd2 to obd1 harness and now got the prob.
    No p28 is stock
    Note that the current motor is an obd1 so it should be the other way round :blink: thats why i donno whats happening
  6. pissedoffsol
    :bash:
    JDM d15b IS a sohc VTEC motor.
    the p28 shoudl work fine.
    either your ecu is fucked, or your conversion harness is fucked. most likley, its the harness.
    do you have any CEL's?
  7. vtecjdm
    Heh yes pissedoffsol.
    Well i got a o2 heater cel, but i am pretty sure that it wont put the ecu in limp mode. I will eventually get a 4 wire o2, but i dont think it will solve the prob <_<
    Damn
    wtf .. everything works great its just this rev prob over 5000.
  8. Som1Dies2Nite
    Som1Dies2Nite Member
    At least your revs up to 5k..My brothers wont pass 3.5k which i believe is the limp mode rpms.
  9. vtecjdm
    [post=536340]Quoted post[/post]​
    [/quote]
    :blink: 3500 only ?? .. seems i`m not alone with this prob
