rex
Discussion in 'Civic and CRX - EF' started by rex41, Nov 19, 2009.
  1. rex41
    rex41 New Member
    I have a dx crx. N I want to know witch engine wud be good to boost . I wana hit 300 or 350 hp? Any idea? Thanx 4 the suport .....
  2. INJEN78
    INJEN78 HS LEGEND
    OHIO
    bseries turbo..
  3. OGMatt
    OGMatt Not a real OG lol
    vic B.C. Japanada
  4. rex41
    rex41 New Member
    <br />
    <br />
    I wana be able to smock thi neon srt4. So whitch sep up wud u recomend . Thanx 4 the suport .
  5. rex41
    rex41 New Member
    <br />
    <br />
    X2?? Wats that
  6. OGMatt
    vic B.C. Japanada
    it's times 2 ...... Wow noob much. My mom knows what that is...
  7. Bobby17772
    Bobby17772 New Member
    Enfield, CT
    never build a car/engine to beat one car or one kind of car because there will ALWAYS be one thats faster then you
  8. INJEN78
    INJEN78 HS LEGEND
    OHIO
    yep..but my friends all motor type-r ef walks on srt's
  9. Bobby17772
    Enfield, CT
    oh yeah without a doubt a b-series either all motor or boosted would blow away a lot of cars just because or the tune and power to weight ratio. it also depends on how you build it, because if you just slap a turbo on it and call it a day you would pop the engine like it's your job, but if you actualy take the time to build it and tune it, it'll be one bad car
  10. rex41
    rex41 New Member
    <br />
    <br />
    Oh. Okay. Well I have a b18b. N im tryin to boosted it. So I was just wonderin if it wud handle good wit turbo......
  11. GlassHeadlights
    Calgary, AB
    Slam the compression way down first, then build it.
  12. rex41
    rex41 New Member
    <br />
    <br />
    How I do that..? Iwana know more about all this.. So wen I get to do the swap I know twat they doin..
  13. GlassHeadlights
    Calgary, AB
    Wtf is with the "<br />"?
    Anyway you need low compression pistons. That motor is in the 11:1 compression ratio range when you want it in the 8.5:1 range, maybe higher but not much.
    What you need to really do is a shit load of researching and reading. Search Google for turbo, building a motor for turbo and tuneing, tuneing, tuneing...the most important part of a turbo build.
  14. eg6sir
    hahaha.. what??!?
    a b18b is in the 9.2:1 range.. lol..
    b16s dont even have that high of compression ratio..
  15. INJEN78
    INJEN78 HS LEGEND
    OHIO
    lmao wow...you can turbo the stock LS and make around 250hp safely..or you can upgrade rods,bearings,and rod bolts and run higher numbers
  16. rex41
    rex41 New Member
    <br />
    <br />
    Idk?? But thanx anyways.. Ill see if get this done by the end of this year.
  17. phunky.buddha
    Dallas / Fort Worth, TX
    If you search "tuneing" you're not going to find the kind of stuff you're going to want to follow. ;)
  18. GlassHeadlights
    Calgary, AB
    Ahh shit, I was thinking of the JDM B18C version. I assumed it was JDM because he didn't say "B1".
    You're right Cal, OBD1 conversion and a chipped P28 ECU or Hondata ECU.
    Fuck it, I'll stick to reading and not posting.
  19. phunky.buddha
  20. ZCpowerdSI
    ZCpowerdSI New Member
    ON, Canada
