UNDR8D
...has a job!
Did some work with the new rear shocks on Saturday morning:
Cut off the old threaded stud, leaving some material to run a die over
This one is upside down for some reason:
Threads cut and new heim threaded on:
Used some small diameter tubing, drilled out the center on the lathe, and made stand-offs so the heim can articulate:
And doing the same with a slightly larger tubing, created sleeves for the inside of the tabs, as these shocks are being used a bit outside of their intended application:
All done:
I'll have the bag and shock mounts done by early next week, then, I need to work on adapting a Camaro rear stabilizer, and then, maybe then, the rear suspension will be done....
All done:
