RIGHT SIZE TRUBO FOR B20B
Discussion in 'Forced Induction' started by byron646, Jul 13, 2005.
  1. byron646
    byron646 Junior Member
    hey guys i was going to turbo charge my b20b, its stock, i was thinking of a t3\t4 set up but what trims would be recommendable????? i was looking at this turbo with a 50 cold side and 83 i believe hot side, give me suggestions, thanxs, i dont wanna get the wrong turbo, i wants omething to spool up completly at like 4000 rpm or 5000 rpm, thanxs
  2. formby
    formby learning in progress
    t3/t4 .58/.63
    T3 .60
  3. byron646
    well would a 50cold and 83 hot work??? if so when will it spool up???
  4. pissedoffsol
    thats toally backwards.... that turbo sucks.
    t3/t04b .63a/r .48/.63 is what you want.
  5. byron646
    my bad but expline it to me why would it be backwards, what would happen if i put a 50\83 turbo in my car?? woudl it spool? when, expline please, thanxs
  6. formby
    dude you got your answer........
  7. MikeBergy
    MikeBergy Blah blah blah....
    Central Coast, CALI
    It'll spool up real slow. The hot side being an 83, would take
    FOREVER. the lower the A/R the faster it'll spool. The cold side would run out of steam before you hit redline. It sucks for those two reasons.
  8. pissedoffsol
    it would lag like hell and have no top end either.
    you want the turbine to always be smaller than your compressor.
  9. MikeBergy
    Central Coast, CALI
    haha, I beat you to it.
  10. pissedoffsol
    lol synchronized posting :p
  11. MikeBergy
    Central Coast, CALI
    It's the new olympic event, to be held in conjunction with curling.
  12. brian11to1
    brian11to1 Senior Member
    I asked the same question not to long ago. I got a shitton of off topic posts about tuning software, when i only asked about the A/R, fuel injectors and cams.
    So be prepared for this to go haywire too.
    Here's my link... http://www.hondaswap.com/forums/index.php?showtopic=58143
  13. formby
  14. MikeBergy
    Central Coast, CALI
    I gave him the same answer I gave you, did I not? I'm not even a turbo guy, as I just spent a ton of money on my all motor setup, but I did a bit of research for you nonetheless, don't be ungrateful.. At least I learned a bit for myself in the process.
  15. brian11to1
    I understand, I wasnt talking about you at all. I appreciate what you said.
  16. byron646
  17. micah
    micah Senior Member
    panama city beach, florida
    kinda big, youd lag like shit.
    plus the b20 doesnt rev THAT high so you wouldnt hold boost very long.
    also, those ss autochrome and xs power ebay kits are pure garbage. the manifolds crack and leak and the turbos have even split in half
  18. byron646
    na na i dont plan on getting it from e bay. i juts used it as an example,, well anywhy at how many rpm will this thing start to spin?????
  19. CiViC_SOHC
    CiViC_SOHC Senior Member
    that is the same turbo you were talking about the first time you posted...they all said it sucks so why do you keep bring it back?..get a T3 with lower hot and col I know for a D series a .42/.46 I believe is good the spool hits at like 3300 and it stays all the way till red line...read this it will help you out...
    http://www.beesandgoats.com/boostfaq/g2icturbo.html
  20. pissedoffsol
