Rmp gauge/engine "yaws" at idle...god help me
Discussion in 'Civic and del Sol - EG and EK' started by 98HatchVtecRatio, Nov 13, 2007.
  1. 98HatchVtecRatio
    98HatchVtecRatio New Member
    Rmp gauge/engine "surging idle"...god help me
    Hey you guys. After doing an engine swap, i was soooo happy that it worked, until i let it idle for about 10 second to notice the Engines rmp gauge "yaws", (moves from like 1gs to like 2gs). Now, from what i know from previous experience, it must be a vacuum leak, (i dont see any open "tubes"). or it could be the IACV, (which i highly doubt because it worked fine before. i just dont know what to do you guys. i am going crazy. I did find on the intake manifold a "taller black box that says DENSO on it" had a hole for a tube. now the question is does anyone know what it does? its got a plug on it, so it is a sensor and its on the intake manifold on a 1996-1998 civic obd2 non ex manifold. IF anyone could tell me what that sensor does and where that tube that should be on the back of it goes, ill so appreciate it. its off to the passage side of the throttle body and it stand tall. or if anyone else could please help me and tell me what else could make the engine yaw that would be GREAT. please, if you know what i am talking about, please help me. thank you so much, dave
  2. 98HatchVtecRatio
    Please help me....anybody? thanks
  3. chestercheeto48
    chestercheeto48 Senior Member VIP
    madison, WI
    Yaw is a rotational direction in relation to flight. If you are experiencing yaw you must depress the rudder pedal in the oppisite direction of yaw you are experiencing.
    As for the surging idle I am not sure. Try searching surging idle it might get you some results.
  4. 98HatchVtecRatio
    did i forget to mention i converted my civic into a PQ-1000 Air Plane? lol jk.
  5. chestercheeto48
    madison, WI
    Now that is an unusual mod......
  6. 98HatchVtecRatio
  7. Matts96HB
    Matts96HB . Moderator VIP
    Ok, surging ide. I had this problem in my hatch when I did an LS swap. It turned out to be the IACV. Not that it was bad, just needed a 3-2 wire conversion. What swap did you do? Give me that information and I can probably give you a good idea of what to start with.
  8. alEXej8
    alEXej8 New Member
    Hubbardston, MASS
    I was gonna say a leak in the intake manifold.
    btw its R.P.M. gauge. not Rmp. RPM stands for Rotations Per Minute.
  9. 98HatchVtecRatio
    matt, thanks for NOT pointing out my typing in-perfections like SOME PLP. ahahah jk. Anyways i put an 92-95 1.5l engine in my 1997 civic. i set the engine all up for obd2 though, using an obd2 intake and harness. the engine are generally the same thing. ii also heard (due to the Iacv) air bubbles in my radiator lines could cause such a thing. i am still stumped the that sensor is and where that tube goes, i blocked it off for now with a screw. tommorrow i am going to try to redo my whole intake manifold and find out Wtf is happening....i just really knew where that tube was supposed to go...
  10. alEXej8
    alEXej8 New Member
    Hubbardston, MASS
    do you have a vacuum guage to check if you are loosing vacuum? or i know of some diagnostic tool that makes a sort of smoke, and if there is a leak it will suck up the smoke and you can find where the leak is coming from. (if that makes sense)
    oh and i wouldn't have corrected you if you misspelled it once but you did it twice so i thought you didn't know. lol
  11. 98HatchVtecRatio
    ahhah i was only kidding alEX ahaha. i was REALLY drunk when i typed, i had to write it 4 or 5 times over lol jk too. Thanks a lot for the tip with the smoke; i am going to definitely try it before i go about doing the WHOLE intake manifold. thanks alot again!
  12. 98HatchVtecRatio
    holy crap you guys! was just about ready to roll up a fatty and blow it into my intake manifold, (ahahah another joke...sorry) and instead, i checked the radiator fluild and it was pretty empty :(. so i added more in, (go figure! :O ) AND LOW AND BEHOLD! the surging stopped....so i called my grandmother in Dallas texas and finally called the law suit off, let me tell you, my attorney almost crapped his pants...SO i was all hyped up and i was tightening a bolt to my spindle, the engine swap was a success,,,and SNAP :eek: i tightend the bolt too much and it broke the stud off...i almost crapped my pants....:locked2:
  13. alEXej8
    alEXej8 New Member
    Hubbardston, MASS
    damn thats good you figured it out, but it sucks you broke that bolt. i guess you better roll up that fatty and smoke it anyways haha.
  14. 98HatchVtecRatio
