rod and main bearings
Discussion in 'General Tech and Maintenance' started by Periculum, Aug 18, 2005.
  1. Periculum
    Periculum Senior Member
    Martinez, GA
    I am curious as to why they would sell a set of main or rod bearings if each jounal and respective surface have different sizes. I went to Honda after searching for a 'set' or rod bearings, only to find that each rod will have a different bearing size according to rod/journal size.
    Are the 'sets' that you can buy supposed to be machined down to the right size? seems a little odd that I could order the exact ones I need from honda but not from anyone else.
