Rod Bearings & Main Bearings
Discussion in 'Engine Building' started by Slimtadder, Jan 7, 2003.
  1. Slimtadder
    Slimtadder Senior Member
    Lake Havasu City, AZ.
    I need help do I stay with OEM or go aftermarket? It's a B16, with I hoping 200+ housepower.
    Thanks
  2. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    OEM
  3. Slimtadder
    OEM why? I know normally it's the best way to go but, is like Napa's shit o.k or no?
    Thanks
  4. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    People think that all of honda's shit is crap, and when they start "tunning" there stuff, they replace it with parts that actually have worse quality. True a dx air box is designed to do its purpase and be quiet instead of just being for letting air in. Yes, goind with CAI will help. However, Honda is one of the best engine designers in the world and alot of there stuff that has no diffrance in ride comfort, safety, reliablility, and emmissions they will put the best stuff in there engines. Stuff like bearings, and ignition systems, honda only goes with the best and you will have a tuff time finding better. Also with stuff like tranny fluid, the honda MTF is the best you can run in hondas because honda designed it to work best with there trannys
    (sorry to go so far off subject but you know what i am saying)
  5. chet
    chet Senior Member
    st petersburg, florida
    use OEM Honda for bearings.
  6. Slimtadder
    Where do I find the color codes for the bearings in my B16?
    Thanks
  7. prawjEKt Cx
    prawjEKt Cx Senior Member
    upstate NY
    use OE bearings, but when you get into your bolts and shit, go arp
  8. 5genracer
    5genracer Senior Member
    Frozen north - ND
    there is a set of numbers on the side of the block for the main bearings, and letters on the crank. Match the two up and call the honda dealer, they will know what to do. There are numbers on the rods too.
  9. judonoh
    judonoh Junior Member
    I personally like clevite 77 bearings. Standard makes some good items, but some are crap you just never know. OEM are good also
  10. lsvtec
  11. chris
    chris Senior Member
    nihon
    i also would go with OEM bearings, tried and tru. as for colors/size its all in the helms manual, tells u which ones u will need according to the #'s on the crank and rods.
  12. pissedoffsol
