rod bolt questions
Discussion in 'Engine Building' started by b20 inspired, Sep 3, 2005.
  1. b20 inspired
    b20 inspired Junior Member
    im in the process of building my b20/vtec and i have a questions. for pistons im using je with around 9 to 1 compression. im using the stock crank and rods. i havent found any rod or main bolts for that motor. does anybody make any. will ls bolts work. would it be ok to use the stock bolts for around 9 to 10 psi. thanks for ur help
  2. scottp11
    scottp11 The Seniorest Member....
    El Paso, TX now, originally from Fresno, CA
    I thought you were gonna keep your B16...?
  3. b20 inspired
    im still goin to keep the b16 but it will just become my back p motor im goin to build it up while my b20 is in that way if anything happens i can just put it back in.
  4. brian11to1
    brian11to1 Senior Member
    yea, i dont think you can use stock rods with those pistons. uhm... yea.
    B20B/B20Z crank, rods and rod bolts are identical to B18A1/B18B1. So buy them for that.
