andyrew500
I am using Eagle rods with the ARP bolts. Eagle calls for 28 ft lbs with the supplied moly lube or .0048"-.0052" stretch with oil for the rod bolts. The rods are carried over from my last build. I did not stretch them before, i just torqued em and had no problems. Well now, I am using the moly lube and torqued to 28-30 ft lbs while gauging the stretch, but I am only getting .002-.003" stretch. Should I torque them more or leave at the torque spec? I dont want to overtorque em. Thanks guys.
