Rod journal surface
cheese9988
VIP
I had to replace my crank because one of the journals went out of spec. I found another one from an old integra that is in spec. The only problem is one of the journals has a slightly rough surface, is this a big deal, and if so what can I do to correct it?
You can see if a micropolish will bring it back, otherwise I'd find another crank. You'll also have to get your block line bored for the new crank, just FYI in case you didn't know.
Yes I did not know that, what does that mean?
