rolling fenders
Discussion in 'General Tech and Maintenance' started by spoonhatch, Dec 17, 2002.
  1. spoonhatch
    spoonhatch Member
    hey i got the same prob, my back tires hit that lip when i hit a dip. but when i went to bend it upward, it wouldn't budge. i bent the front with no problem, i think the back is thicker metal. anyone have any other suggestions on how to bend it without damaging the body?
  2. paragus
    paragus Senior Member
    i had that problem in my accord (when i owned it) and i just grinded the lip away. of course i was also doing body work at the same time... if you do grind it.. be sure to seal the exposed metal.. u dont want rust
    the only thing that worries me about rolling the fenders w/ a baseball bat is chipping or cracking the paint.
  3. knowledge
    knowledge Senior Member
    Beale AFB, CA
    I was an idiot and descided to "originally" Just try to crimp the back fender up into itself. Yeahhhhhhhhh bad idea. That chipped the paint. But rolling the fender ever so slowly and slightly will work. I have done it to 3 other cars (of course after learning from my mistake) and the paint never chipped. Because not only does the underside lip roll up towards the fender itself. But the whole fender gets pulled outward(like a fender flare). You don't need to go crazy. Just enough so it stops rubbing.
    Oh and B16 if the wife lets me I could take a trip down and do it. It would have to be after X-mas though bro. Shit is hecktik right now. It would be a good reason for me to check out your new suspension :worthy: .
  4. B16
    B16 Super Moderator VIP
    yay area, CA
    word, you should do that then... especially if you have experience doing it, i just know i'd fuck something up :p
  5. spoonhatch
    spoonhatch Member
    rolling it sounds good, but i cant even fit my finger between the tire and fender, how can i get a bat under there. i wanted to do the grinder idea, but i dont want a chopped up looking lip, maybe i should go to a body shop so they can do it cleanly :blink:
  6. paragus
    ill take pics!
  7. E_SolSi
    ummmm [​IMG] use a jack and raise the car up a few inches till you can fit the bat in there
  8. knowledge
    Beale AFB, CA
  9. wildbillhatchbac
    wildbillhatchbac the OG VIP
    my thoughts exactly . . .while reading this huge discusion about tires rubbing, and fenders rolling . . . use a jack! . . . i guess common sense isn't that common anymore.
  10. spoonhatch
    spoonhatch Member
    ok so what about cutting the lip? i have a angle grinder but it kinda chops and doesn't make clean cuts. what else could i use?
