Capt. Orygun
Win the Day
anyone heard of Pro-Stop Rotors, from what's I've heard their built with Bembro parts...
IMPORTANT REMINDER: Slotted, drilled or dimpled rotors offered as OEM replacements should not be considered appropriate for high-speed track use.
While grooved, drilled and slotted rotors offer an enhanced appearance and add some resistance to the boundary layer of gasses that can build up between the pad and rotor, they are not designed to withstand the extreme temperatures that are produced on the racetrack. If they are used on the track, it is very important that the rotors be carefully inspected and should not be driven on if even minor signs of deterioration are seen. Note, too, that if any products are used on the track they are not warrantable.
Quoted post[/post]]
they are not made by brembo or with brembo parts
they are made by power slot
they are slotted rotors with dimples drilled into the face to give the look of a cross drilled rotor (crap)
heres a little quote from TireRack.com
http://www.tirerack.com/brakes/brakes.jsp?...make=PowerSlot&
once again
if you want brembos GET BREMBOS
stop fucking with this "the look of high performance" shit
