Rough engine idle
Discussion in 'General Tech and Maintenance' started by wanderinman, Jun 18, 2005.
  1. wanderinman
    wanderinman Senior Member
    Raleigh, NC
    96 LS w/ the stock b18b... replaced plugs, wires, dizzy cap and rotor, oil/filter change. Air filter is new, no leaks anywhere. However, it still has a rough idle. What else can be causing this. My only thoughts were fuel filter (which I have and am going to put in) or possibly a clogged injector.
    Air, fuel, and spark are needed for a combustion, duh. My air intake system is kosher, and for the most part my spark system is all brand new, so it must be a fuel problem right?
  2. sihatchback_RL
    sihatchback_RL Senior Member
    Check for leakage of Vacuum hoses and IM gasket. Also, the injector gasket as well.
  3. abdelsol
    abdelsol Member
    Check your timing?
