Rough Idle D16z6
SlowHatch101
I Know Its Slow
i just dropped a z6 in my vx and when i start it the idle jumps betwwn 1000 and around 1700, i've changed the map, iac, checked the wireing it doesn't show any codes
ok i just checked the F.I.T. and adjusted it and started it and code 7 showed after about 30 sec. so i'm about to change the Tps
ok i changed the tps and it idled smooth at 1500 so i tried to idle it down but i only got it somewhere between 1000 and 1100 then i drove it down the road and when i got back it was jumpin between 1000 to 1500
